American plumber water softner
Discussion in 'Water Softener Forum, Questions and Answers' started by Outside42, Dec 11, 2013.
  1. Outside42
    Outside42 New Member
    Dec 11, 2013
    Nj
    May some info could help us ,we had water softener and neutralizer installed water was acidic also hard they said to use blue bag salt that's what we use the problem is the water taste like crap salty and nasty we had all our old pipes removed and replaced with pex what would you guys say thanx
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I would say something ain't working right.
  4. Outside42
    Dec 11, 2013
    Nj
    Where do I start
  5. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Does it taste salty just after a regen? What is the hardness set at? How much water is in the brine tank?
  6. ditttohead
    Jan 9, 2012
    Ontario California
    A softener should have a minimal affect of the tase of water. If you are getting a truly salty taste to the water, it should only occur after a regeneration if there is a problem with the softener and should clear up after running the water for a short amount of time. if you get salty water in the water heater, it will take considerably longer to get that cleared due to dilution issues. If your system produces salty water, you have a problem. Extended salty taste out of a softener would usually indicate a bad or missing riser o-ring, or a short manifold assembly.
    We need more information to help you. A picture of the unit, water source (well or municipla), how old the unit is etc.
    Hope this helps!
  7. Outside42
    Dec 11, 2013
    Nj
    It is a well .always salty taste and has a metal taste .nutr.is w 4 15a nf. Softener is w 430 f. Both American plumber
  8. ditttohead
    Jan 9, 2012
    Ontario California
    Always salty water from a well fed softener would probably be the well and not the softener. If a softener malfunctions and causes salty water, that will go away fairly quickly. Try bypassing the softener and see if anything changes.
  9. Outside42
    Dec 11, 2013
    Nj
    Did bypass water taste like well um water
  10. ditttohead
    Jan 9, 2012
    Ontario California
    Do you have a water report? Calcite and corosex can give the water a mineraly taste, even metallic. The softener adds sodium to the water in place of the Calcium, magnesium, etc. It takes a lot of sodium in the water to afffect taste.
    Did they put the neutalizer before or after the softener?
    What water testing equipment do you have? TDS meter, hardness test? anything?
  11. Outside42
    Dec 11, 2013
    Nj
    Yes I just sent it out .I know it was hard water with lots of magnesium should I try by passing water softner and only use nutrilzer ? I know we keep using salt and I put calcite in nutrilzer 6 months ago
Similar Threads: American plumber
Water Softener Forum, Questions and Answers Water Softener & Plumber advice Jan 12, 2017
Water Softener Forum, Questions and Answers Fleck 7000 / Clack Resin Tank Leak - Plumber Installation Problem or Defect Jun 5, 2014
Water Softener Forum, Questions and Answers Water Softener Drain and what the Plumber told me while getting a quote... Sep 15, 2011
