Am I going to poison my dogs?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jonathan Kozolchyk, Oct 1, 2012.
  1. Jonathan Kozolchyk
    Jonathan Kozolchyk New Member
    Oct 1, 2012
    Seattle
    Hi Folks,
    I made a simple water fountain for my dogs using a small fountain pump and "utility grade" copper tubing (3/8" OD) that I bought from Lowes. Is Utility Grade copper tubing safe for potable water? I didn't solder anything, just bent the pipe to get it out of the way and put a fitting on it to keep the sharp ends out of puppy reach.
    Here's a picture of the fountain (don't laugh at the bends! it gets the job done!):
  2. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    poison? no. electrocute or kill them if the pump should fail? possibly. i would have the plump plugged into a GFCI outlet to be safe, if not just abandon the idea. Why is it needed?
  4. Jonathan Kozolchyk
    Oct 1, 2012
    Seattle
    Thanks Chad! I have the pump plugged into a GFCI outlet. I don't know why, but the dogs like moving water. There are many similar fountains on the market, but they're all a pain to clean. My home made one is a lot easier to maintain.
  5. hj
    Copper is copper, the difference in grades refers to the wall thickness of the tubing, NOT the material it is made of.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    My dog drinks out of the toilet whether the water is moving or not
  7. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    quote; "refrigeration" grade where the tubing is
    cleaned, filled with moisture-free gas, and plugged, so as to avoid contamination of the refrigerant used in A/C&Refrig. machinery.
    It is also to prevent oxidation inside the tubing which could damage the components.
  8. hj
    quote; My dog drinks out of the toilet
    ANd he doesn't complain about you sitting on his water fountain?
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    Nah, he's old and senile
Similar Threads: going poison
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Going from 2 Basin to single kitchen sink; a few questions. Sep 29, 2016
Plumbing Forum, Professional & DIY Advice Wet spot of home foundation, possibly plumbing leak in pipe going through foundation? Jun 25, 2016
Plumbing Forum, Professional & DIY Advice Laughably bad soldering job (is this going to leak?) Jun 12, 2016
Plumbing Forum, Professional & DIY Advice Installing a new faucet, pressure seems too high going from Flowtite piping into new metal piping Mar 15, 2016
