Alternative for hose bib vacuum breaker noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DIYER39, Jun 13, 2013.
  1. DIYER39
    DIYER39 New Member
    May 20, 2013
    Spring Valley, CA
    I recently installed hose bib vacuum breakers that I bought from my local home improvement store for $5. They create a ton of noise in the pipes when using the spray nozzles. It even sounds like the pipes shake a little inside the wall. I also dont know if that noise causes wear and tear on the pipes since my wife gardens everyday 365 days of the year. After doing my research on google I noticed that this was a fairly common problem with vacuum breakers and relates to the spray nozzle opening and closing constantly. Obviously there is no noise from pipes when water flow stays on or water flow stays off. I would like to keep using the spray nozzles for gardening, washing cars, things like that because it would really be a pain to always have to walk back and forth turning the valve on and off. Can someone please recommend an alternative or let me know if I am doing something wrong. I want to just throw the vacuum breakers in the trash but I worry about my families safety. Ive included a few pictures for reference.
    Is there a better alternative that I dont know about? Maybe a different type of backflow device.
    Am I just using cheap vacuum breakers?
    Is all this pipe noise something that I should just be ignoring and not harmful to pipes? DSC_8878.jpg DSC_8879.jpg
  2. DIYER39
    DIYER39 New Member
    May 20, 2013
    Spring Valley, CA
    Anyone? Am I just stuck with the pipe noise and shaking?
  4. hj
    WE install hose vacuum breakers every day, and our customers do NOT have that problem, so the obvious answer is that the problem is that particular brand of BFP.
  5. Jet
    Jet New Member
    May 20, 2014
    Texas
    Could you provide the manufacturer?
    I've run into a similar situation. My original BFP's were rather quiet, but the replacements purchased at a local home center (BFP made by TE-Cheng, model 9500) create a lot of noise. Would appreciate a recommendation. I'd like to avoid the trial and error required to find a reasonable replacement. Thanks.
  6. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  7. hj
    We use Vatts BFP, gut part of your problem si probably the flow through it when the nozzle is at a partial flow setting.
Similar Threads: Alternative hose
Plumbing Forum, Professional & DIY Advice Slip-on spout adapter's set screw DESTROYED my copper pipe - how to replace the pipe or alternative? Jul 9, 2014
Plumbing Forum, Professional & DIY Advice Basin Wrench Alternative? Mar 11, 2014
Plumbing Forum, Professional & DIY Advice Alternative to ball valve with waste Feb 6, 2014
Plumbing Forum, Professional & DIY Advice Can anyone propose an alternative pressure balancing loop? Jan 22, 2014
Plumbing Forum, Professional & DIY Advice Is this a "P" or "S" Trap or which is the better alternative? May 25, 2012
