I have an active sump pit attached to a footing drain - goes off 3-4 times per hour for ~20 seconds each time. Right now I have 2 Hydromatic SKV50 pumps with SJE Rhombus floats. It is currently wired with an alternator so they switch back and forth each time the pump goes off. The guy who is likely to service this system for me going forward suggested that instead I use a primary pump and a backup pump, the float for which would be set at a slightly higher water level than the primary pump to only go on if the primary fails. His rationale is that this would make the system a lot easier to maintain by avoiding all the wiring required for the alternating feature. He also suggested changing the switch to something that wouldn't ever get stuck (can't recall what, ball float maybe?).
I had called Hydromatic in the past and they said it was good that both pumps run regularly, so I am a bit concerned about having a backup that may not run for a year and then doesn't work when called upon. Our exterior footing drain is attached to a pit in the front yard which is not easy to access, so it would be hard to test the backup in between the annual maintenance calls. Does anyone have any strong opinions on whether having alternating pumps is worth the extra wiring complication vs. just a primary and a backup?
Thank you very much!
