Alright Here's the Deal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TheSisko, Jul 13, 2009.
  1. TheSisko
    TheSisko New Member
    Jul 8, 2006
    I posted earlier about a septic odor all over the house.
    Problem solved we had a huge clog in the PVC (4") in the slab. It took Liquid Fire, the largest snake and finally something the plumber called the "sewing machine". No more clog
    And for the coup de gras, apparently there's a sagging place in the pipe where the slab has settled. The plumber thinks its under the kitchen just before joining into the mainline out to the septic tank
    He said he's not sure whether pipe has broken open and were losing water into the slab (pipes are buried in the concrete). He said look for water around the house and cracking.
    Any thoughts from your experiences
  2. hj
    drain
    I am not sure what a "sewing machine" is or how effective Liquid Fire was, but if the plumber had to use it, then I question whether he even had the correct snake. There is almost NO WAY to diagnose whether there is a sag in the line without using a video camera. Unless the septic tank plugs up so the line can fill with water, and it has to be plugged for days, there is no way water can come up to the surface around the house where you could see it. To do that water would have to rise above its "own level" and gravity, (plus the laws of physics will not allow that to happen). I think he was either trying to "dazzle you with his brilliance", or "baffle you with his BS".
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would think its the latter...
    I've never heard of a sewing machine used for drain cleaning either....
    I have also never used liquid fire to clean a drain...
Similar Threads: Alright Here's
Plumbing Forum, Professional & DIY Advice Here's my bath plan...will this fly? Feb 16, 2017
Plumbing Forum, Professional & DIY Advice There's a hose bib before the RPZ and PRV with no backflow prevention... Jun 11, 2016
Plumbing Forum, Professional & DIY Advice Installed a new outdoor faucet, but there's nothing behind it to screw into... May 15, 2015
Plumbing Forum, Professional & DIY Advice 4 feet below the upstairs sink there's a dirt blockage. Aug 14, 2014
Plumbing Forum, Professional & DIY Advice Installed new dishwasher which is a bit smaller, now there's a gap Apr 30, 2014
