All four burners will not ignite at the same time.
Discussion in 'HVAC Heating & Cooling' started by gordon33, Dec 9, 2010.
  1. gordon33
    gordon33 New Member
    Dec 9, 2010
    Michigan
    Hello All
    This Comfort maker furnace is about 10 years old.
    All four burners will not ignite at the same time. The start up looks good until burner ignition. The first burner ignites because it is close to the igniter, and the second burner also ignites. But the third and fourth burners usually takes 10 to 30 seconds longer to ignite. The flame just doesn't cross the gap quickly.
    I have no idea what the problem is. Mechanical defect in the burner apparatus? It doesn't appear to be a draft problem or gas pressure problem. Once all 4 burners are ignited the four flames look the same.
    Thanks in advance for any ideas.
    Gordon33
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    I have to wonder where all that unignited gas is going.
    Do you have
    "a concussive type ignition which is both frightening and often dangerous"?
    "Step 1 - Clear the Ignition Ports
    Ignition ports are tiny holes embedded in the exposed side of the burners. The restriction of these ports is the root cause for a delay. Clean the ignition ports with the sewing needle. Ensure that you do not increase the size of the ignition holes as this will further aggravate the problem."
    Maybe soaking them in some kind of a solvent will also work.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Get the unit properly cleaned, it sounds like the pass over ports are plugged up
Similar Threads: four burners
HVAC Heating & Cooling Seems my new millvolt gas valve turns off PILOT and MAIN BURNERS? Oct 12, 2015
HVAC Heating & Cooling Why Is It Wrong to reduce output of furnace by eliminating burners? Jan 22, 2012
HVAC Heating & Cooling Help with Hydronic Heating- main burners not kicking on Apr 1, 2009
HVAC Heating & Cooling Burners for Making Maple Syrup Jan 22, 2009
HVAC Heating & Cooling Only half of furnace burners ignite--looking for troubleshooting advice... Dec 8, 2007
