Air tub blower placement
Discussion in 'Shower & Bathtub Forum & Blog' started by dlr77057, Sep 25, 2006.
  1. dlr77057
    dlr77057 New Member
    Sep 25, 2006
    I have a Hydrosystems air tub that i have yet to install.
    I was reading how some air tub blower motors are loud and they can be located 10-15 feet away from the tub.
    Does it seem to be the case that the blowers are loud? and does anyone know about Hydrosystems specifically?
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Every spa I've had with an air blower was so noisy we seldom used the air. If you can easily locate the blower remotely, do it.
  4. jadnashua
    I have an air tub from Jason International (a son of Jacuzzi that went his own way). I don't find the airturbine particularly noisy...it's not quiet, but not objectionable. Most of them can be remoted, if that is a problem. Note, if you do that, the air column will end up cooler since the heat is generated in the turbine. Insulate the line well.
  5. Mickster
    Mickster New Member
    Sep 26, 2006
    I can't speak for your system, but one of the reasons we chose the Bain Ultra Duo was seeing the demo at the dealer. They deliberately kept the motor underneath the tub rather than remotely mounting it because it was so reasonably quiet compared to other tubs we'd seen/heard.
    The water seemed louder than the actual motor.
    Our sales person has this tub in his house and did not remotely mount the motor for it.
    That said, if you can get to a place where they actually have demos (seems few and far between) you might want to take a listen.
    We certainly can remotely mount it if we like, however, we are probably going to keep it under the tub. In the worst case, we can access the motor and remove it to relocate it in a closet.
    If you are not planning to put in a tile front, and will have panel access to the tub, as we do, then I would strongly recommend trying it with the motor underneath. If it is too loud, remove the motor later, and remotely locate it.
    Good luck!!
    Michael
Similar Threads: blower placement
Shower & Bathtub Forum & Blog Can't find a shower faucet replacement Feb 7, 2017
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
Shower & Bathtub Forum & Blog Replacement Delta bath faucet/diverter Nov 2, 2016
Shower & Bathtub Forum & Blog Identify and find replacement challenge! Sep 12, 2016
Shower & Bathtub Forum & Blog Shower replacement, 1.5" to 2" conversion - do I need to replace vent pipe too? Sep 9, 2016
