Air Sealing Electrical Boxes (Expanding Foam.)
Discussion in 'Electrical Forum discussion & Blog' started by molo, Jun 24, 2012.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Hello,
    I'm working on a new renovation with new wiring and access to the open framing. I would like to prevent air leakage around all electrical boxes.
    One thought I have is to use expanding foam around the outside of the boxes. Is this OK?
    Thanks in Advance,
    Bill
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Depends on the foam
    read the instructions
  4. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    There are specific foams for closing holes drilled to chase NM thru framing. Look at some of that.
  5. ss3964spd
    ss3964spd New Member
    Jan 17, 2006
    Anyone know what this foam is and where it can be found?
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Google is your friend. Search for:
    fireblock foam electrical
  7. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Amen.
    I saw rows and rows of it at Home Despot just yesterday.
  8. molo
    molo Member
    Sep 23, 2006
    Cold New York
    I talked to a rep. at Dow today. They said that their standard "great stuff" foam is OK around electrical boxes and insulated wires. However, it is not OK inside the box or in contact with bare copper.
  9. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    if i were you, i wouldn't use the normal great stuff. get the stuff for windows and doors. it does not expand as much and will not push your boxes out of square if you use too much. it will bow window frames if used incorretly, i've done it myself.
  10. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    I'd definitely try to ask a local electrical inspector.
  11. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    I doubt that fireblock caulk or foam is required. The OP is not sealing fire rated areas, except for maybe floor penetrations and that is only is the floor is a rated assembly.
  12. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    My concern would be that certain products would be banned as blocks around boxes due to their flammability.
Similar Threads: Sealing Electrical
Electrical Forum discussion & Blog Electrical Inquiry Saturday at 12:34 PM
Electrical Forum discussion & Blog Electrical shorts Friday at 4:54 PM
Electrical Forum discussion & Blog Electrical supply to barn and garage Feb 9, 2017
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
Electrical Forum discussion & Blog Electrical wire accidently charred. Dec 31, 2016
