Air release ? in a converted gravity system
Discussion in 'HVAC Heating & Cooling' started by xjmllc, Oct 26, 2007.
  1. xjmllc
    xjmllc New Member
    Oct 8, 2007
    GIS
    Cleveland, Ohio
    First off, forgive me if my terminology is off.
    OK, I had an original "gravity" boiler system. The old expansion tank was way up in the attic. The tank/leftover pipes are higher than any radiator. I'm concerned about the air trapped in these pipes without a radiator to bleed. Do I simply insert an air release valve like the Taco slimeline hy-vent model below. Please see diagrams.
    OLD SETUP
    [​IMG]
    NEW SETUP??
    [​IMG]
    http://http://www.pexsupply.com/product_dtl.asp?pID=4551&cID=305&brand=Taco
    [​IMG]
    thanks!!
  2. HvYhitter
    HvYhitter New Member
    Oct 17, 2007
    good question.. because you will never get the air out of the lines above the highest air vent in your system I am betting.
  4. xjmllc
    xjmllc New Member
    Oct 8, 2007
    GIS
    Cleveland, Ohio
    I'm now almost certain I need to connect the pipes (based on the first picture above) it's a supply and return piping through the tank.
    Still, how do I remove this air in the pipes above the highest radiator (1 floor below)????
    1) Just connect the pipes
    2) Connect the pipes and add an air release in between them
Similar Threads: release converted
HVAC Heating & Cooling Leaking Presure release valve Feb 13, 2008
