Air in water lines?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BrianF, Sep 14, 2004.
  1. BrianF
    BrianF New Member
    Sep 14, 2004
    This topic has come up several times but my scenario seems different. When turning on the water I notice air (or something) chuckling out of the lines. The kitchen sink sounds the worst and I think even vibrates the faucet a little when it does this.
    Does anyone know what this is or how to solve it?
    Thanks,
    Brian
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Water Source
    If you have a municipal water supply, air usually does not accumulate in the water distribution system, if there is any it will work its' way out within seconds in most cases. If your water source is from a well, there could be a problem with the system that will require a professional to inspect it.
Similar Threads: water lines
Plumbing Forum, Professional & DIY Advice Basement water lines Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice How to pressure test new water lines? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Back flushing water lines in a home filled with dirt, silt and gravel Oct 5, 2016
