Air in the Pipes
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rburt5, Jan 21, 2006.
  1. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    I recently had a new Well-Rite water pressure tank installed in my house. Lately we have been getting air in the pipes. This especially happens in the evening for some reason. We turn on the faucet (any faucet in the house) and water comes spitting out at us like the pressure had been building up too high or something. The tank it set to about 50psi. Any ideas about what could be causing it and how to fix it?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What kind of tank was your old one?
    bob...
  4. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    I don't remember the brand of my old bladder tank. It was a dark red color. The person who installed my Well-Rite said that the old one wasn't a very good brand. The problems with air in the pipes didn't start until after the new one was installed. What are you thinking might be the problem?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Sometimes if you have a galvanized tank, there is an air making system installed. With this system, you have to uninstall it before installing a bladder tank. But I have never seen any red galvanized tanks.
    Do you have a check valve at or near the tank? A brass or plastic large coupling looking device?
    bob...
  6. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    My tank does have a brass check valve. Although I know very little about well pumps and bladder tanks, I don't think the old bladder tank was galvanized. It was basically identical to the new one, just a different color and manufacturer. Could the well pump have anything to do with the air getting in the pipes? Actually, does my problem even sound like there is air in the pipes or is it something else causing the faucets to spit at us?
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    The tank itself wouldn't have a check valve. It would have to be installed in addition to the tank. Be sure your not confusing a brass tank tee for the check valve.
    I have been assuming you have a submersible pump. Am I correct?
    bob...
Similar Threads: Pipes
Pumps and Tanks Well Forum & Blog. Water is life. Hot water from cold water pipes Jun 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch and freezing pipes Jun 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New wider pipes, lower water pressure Sep 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well won't prime after pipes are replaced. Apr 9, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Replaced shallow well pipes and put in pitless adapter: Now no water pumped Jul 26, 2012
