Air Handler Blower Problems
Discussion in 'HVAC Heating & Cooling' started by GRedwine, Jun 9, 2008.
  1. GRedwine
    GRedwine New Member
    Jun 9, 2008
    The unit is a Goodman split system about 5 years old.
    Sometimes the air handler blower fails to come on.Switching the fan switch from AUTO to ON will kick it on IF you make the compresor turn off first by moving the slider.Also turning the unit OFF and waiting till the pressure shuts up and restarting usually works.
    Sometimes it goes for days without a hitch and sometimes it's every hour or so.
    without just replacing parts by trial and error,(which is popular in our area),Where would you start testing?
    Gary
  2. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    Possible causes.
    1. failing relay
    2. A pressure/temperature sensor that is supposed to turn on the fan?
    3. Motor or motor starter problem.
Similar Threads: Handler Blower
HVAC Heating & Cooling American Standard Air Handler Install Jul 24, 2016
HVAC Heating & Cooling Connect drain to air handler Jun 8, 2016
HVAC Heating & Cooling Advice needed on HVAC air handler options Jun 6, 2016
HVAC Heating & Cooling nordyne air handler.need help wiring it Aug 30, 2015
HVAC Heating & Cooling Air handler to duct connector Apr 7, 2015
