Air Handler Access
Discussion in 'HVAC Heating & Cooling' started by jerome8283, May 17, 2011.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    I have central air in my new home (new to me but old in age). I noticed the air handler requires what looks like a key which I do not have. Is there a standard key for this or is this not a key and some sort of tool?
    Thanks
  2. jadnashua
    No idea, but it's hard to tell without some brand and maybe model info...we can't see it to tell! Most that I've seen only require a wrench or screwdriver to open.
  4. jerome8283
    Oct 4, 2006
    New York
    You’re a genius! I'mi such an idiot! A srewdriver worked. :)
  5. jerome8283
    Oct 4, 2006
    New York
    Jim -
    Obviously, this is my first time opening this. I was prompted to open it because of a musty smell that I get from some of the registers. The evaporator coils are rusty. Is this something I should be concerned about? The unit ran fine all season last summer. I have not turned it on yet this year.
  6. jadnashua
    The coils themselves are probably copper, the support framework might be something that can rust. Ideally, they'd use metals that can't rust since the evaporator coil generally is wet while running. A good cleaning may get rid of the musty smell. You want to ensure that the drain is clear as well. If you aren't careful, though, you can bend the fins and decrease the efficiency of the unit.
    How old is the coil? If you can post a picture, the pros may have some suggestions.
  7. jerome8283
    Oct 4, 2006
    New York
    Thanks Jim. I will post pics tomorrow. The unit is more than 12yrs old.
  8. jerome8283
    Oct 4, 2006
    New York
    Here are some pics. I also found instructions in side the unit, VDX/VHE Series Fan Coil Unit?
  9. jadnashua
    First thing noticed is that it could use a good cleaning! Other than that, see what the pros have to say.
  10. jerome8283
    Oct 4, 2006
    New York
    Yeah I'm planning to do that.
Similar Threads: Handler Access
HVAC Heating & Cooling American Standard Air Handler Install Sunday at 5:02 PM
HVAC Heating & Cooling Connect drain to air handler Jun 8, 2016
HVAC Heating & Cooling Advice needed on HVAC air handler options Jun 6, 2016
HVAC Heating & Cooling nordyne air handler.need help wiring it Aug 30, 2015
HVAC Heating & Cooling Air handler to duct connector Apr 7, 2015
