Air Control Valve
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Chrisw1958, Mar 16, 2010.
  1. Chrisw1958
    Chrisw1958 New Member
    Mar 15, 2010
    Kenner
    What is a air control valve and what does it do on a bladderless tank? Is it mandatory?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It maintains the air cusion in the top of the tank and no, it's not strictly mandatory but without it you will have to drain the tank and re-establish the air cusion a couple times a year or more.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There is more than one type of setup. Peter is referring to one that allows air INTO the tank. When the air bleeders are in the well, a float-style AVC works to allow the excess air OUT of the tank.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    yes, I forgot those. But nobody has uses that set up around here.
  6. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    They are quite common in this part of the country. Most of the wells around here use regular galvanized tanks, probably 2:1 or more. If you see a sub/galvanized tank, it probably has a bleeder.
  7. Chrisw1958
    Mar 15, 2010
    Kenner
    This had a steel tank and whenever the pump shut off it made a little pffft sound. My boss put in a bladder tank and it is getting air probably from the well as I have learned here. I guess we need to go back with a regular tank but I wondered where to buy the float style avc? Where do you get galvanized tanks all I see is steel with epoxy liner?
  8. Chrisw1958
    Mar 15, 2010
    Kenner
    What is 2:1 or more mean?
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Epoxy lined is the "new and improved" galvanized-style tank.
    The AVC is Grainger part# 7P020 . Probably also available at any good plumbing wholesaler.
  10. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    Ratio of galvanized tanks to bladder tanks. For every 1 bladder tank in this area there are probably 2 galvanized regular tanks.
  11. ballvalve
    Dec 28, 2009
    northfork, california
    Sears online sells some big glasslined tanks quite cheap.
  12. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Funny how they do different things in different parts of the country. Nobody installs non bladder air tanks up here. I have not used one in better than 30 years. Doubt I could even get one from my wholesaler unless I special ordered it.
Similar Threads: Control Valve
Pumps and Tanks Well Forum & Blog Patent that was supposed to fix all problems with air volume control valves Feb 16, 2016
Pumps and Tanks Well Forum & Blog Air Volume Control Valve Function Feb 5, 2016
Pumps and Tanks Well Forum & Blog Shower control valve removal May 18, 2015
Pumps and Tanks Well Forum & Blog Dole flow control valves Feb 4, 2014
Pumps and Tanks Well Forum & Blog Final FINAL installation pictures of cross, control valve, pressure tank, and pump! Dec 5, 2012
