Air check valve closed after regen
Discussion in 'Water Softener Forum, Questions and Answers' started by KMcG, Dec 16, 2010.
  1. KMcG
    KMcG New Member
    Dec 16, 2010
    Ireland
    Hi all,
    I have been trawling the web on this issue with no success. My water softener (Autotrol 255 by the look of it) started to overfill the brine tank after some cold weather last winter. This is being caused by the air check valve (on the 255 valve body, not in the brine tank) being closed all the time. I can do manual regens by removing the float and catching it before any air get sucked in. I know the ball should float after the regen, but since the last step seems to be to flow hard water into the brine tank, how can this be. The ball will only float in soft water.
    Thanks,
    Kieran
  2. Gary Slusser
    Retired
    The ball air check floats in/on any type water. If the ball is down in the 'glass' there's no water in the 'glass' and that is the problem. Or if the ball were stuck down, under the water.
    In that case you aren't getting water back into the brine tank as you should. The cause would be a blocked injector screen or injector or the internal port between the screen and injector. The ball will only float IF there was water going to the brine tank as part of Refill, which happens during the settle rinse.
    Overfilling the brine tank means no or incomplete suction (Brine Draw) leaving more water in the salt tank than should be, and incomplete regeneration, and that is caused by a suction air leak during Brining and then Refill putting back the water that was supposed to be sucked out, overfilling the salt tank. Causes are air leaks in the brine line fittings, blocked injector and or screen. Kinked/blocked drain line or low water pressure.
Similar Threads: check valve
Water Softener Forum, Questions and Answers Air check valve replacement and brine float questions Dec 11, 2013
Water Softener Forum, Questions and Answers Should air check valve in Autotrol 255 be full of water or air? Feb 1, 2009
Water Softener Forum, Questions and Answers Please check my 5600sxt setting Thursday at 7:02 PM
Water Softener Forum, Questions and Answers Check out the picture of my shower fixtures Nov 1, 2016
Water Softener Forum, Questions and Answers new 7000sxt - sanity check Apr 21, 2015
