Air chambers help water pressure?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hologramdr, Mar 5, 2005.
  1. Hologramdr
    Hologramdr New Member
    Mar 5, 2005
    I am currently taking a home repair class on plumbing and the teacher said that air chambers will help increase water pressure as well as get rid of water hammer. Is this true? It doesn't seem to make much sense to me unless the difference is really small. Thanks.
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Air chambers do not increase the water pressure, they only stop water hammer.
  4. hj
    aie chambers
    In a very small way, but they do not increase pressure, they can maintain it. In certain situations, namely a very long or small water main, when a faucet is opened quickly, the pressure can drop "momentarily" due to the inertia of the water. The air chambers, or an expansion tank, being partially filled with compressed air will try to release that pressure when the incoming pressure drops to zero. When they do that, it will eliminate a "reverse" water hammer when the water starts to move, and also keep the pressure constant during that period.
  5. proxybox
    proxybox New Member
    Mar 4, 2005
    Los Angeles, CA
    I would use a water hammer arrestor
    I would rather use a water hammer arrestor than a air chamber. Air can be dissolved over time and reduce the amount of room that the water can 'move' when a valve is closed. Sioux Chief and PPP both make them.
    proxybox
Similar Threads: chambers help
Plumbing Forum, Professional & DIY Advice Air Chambers, Pipe behind shower wall that just terminates Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Blank Pipe next to Pipe? Air chambers. Aug 11, 2013
Plumbing Forum, Professional & DIY Advice Expansion Chambers Mar 25, 2010
Plumbing Forum, Professional & DIY Advice Should I use air chambers? Jan 11, 2008
Plumbing Forum, Professional & DIY Advice Air Chambers Oct 13, 2005
