Air Bleeder Valves - O Ring
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Jun 12, 2012.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Just looking at air bleeder valves for baseboards.
    Is one design better than the other.
    One is just a regular thread ...
    The latter has a o ring on the bottom of it, so the valve doesn't truely bottom out onto the baseboard.
    Regardless, I do dope the fitting.
  2. hj
    I have never used anything other than the standard IPS threaded ones. THey do NOT bottom out on the baseboard, but one with an "O" ring would HAVE to bottom out in order to seal.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Standard coin vents or the ones that take a square socket are usually 1/8" NPT, no O ring
  5. chefwong
    chefwong Member
    Jun 14, 2006
    No a fan of the O ring. Bought one.....when loosening the setscrew to bleed it, you need a box wrench (on my baseboard at least cause it's slim) to hold it in place - s the setscrew force will turn it.
    The latter type, on the same style baseboard does not do this..
Similar Threads: Bleeder Valves
Plumbing Forum, Professional & DIY Advice Bleeder on copper line shut off valve - Which side? Mar 28, 2015
Plumbing Forum, Professional & DIY Advice Adding baseboard loop - Bleeder question Sep 23, 2011
Plumbing Forum, Professional & DIY Advice PEX home run manifold system shut off valves Sunday at 7:28 AM
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Price pfister shower valves Dec 21, 2016
