Bill white
http://www.tongdapvcpipe.com
agriculture irrigation pipe is a kind of all adopt high strength polyester and the high quality PVC composite material as a raw material; Light weight, good flexibility, bright color, smooth coating; Volume half closed, mobile convenience, unlimited length; Low temperature water keeps tube Hugh soft and elastic; Is the most ideal tool of water-saving irrigation, the current domestic water-saving province, energy saving, production, cost savings, easy to use, to prevent water loss and
soil erosion and soil alkalization, and other characteristics.
agriculture irrigation pipe Features:
1, flow resistance is small, the roughness of 0.008-0.009, water capacity than cast iron pipes increased by 20%, 40% increase in concrete pipe
2, high tensile strength, tensile strength of not less than 23 ℃ 45MPA
3, good resistance to stress, pressure to the outer diameter of 1/2 will not break, good mechanical properties
4, light weight, easy shipping, PVC-U pipe cast iron pipe steel accounts for only 1/5 of concrete 1/2, pipe weighs about the same size, the length of the ink with the ball
1/4 of cast iron pipe, concrete 1/10 lower transportation costs 1 / 2-1 / 3.
5, pipe health non-toxic, no secondary pollution flow, will not produce secondary pollution of the water quality; irrigation pipes under pressure at a stable temperature, not low life
In 50 years.
Applications:
Can be used for drinking water supply,underground pipeline for agriculture, acids and slurries transportation, drainage system, sewerage system, rain, water, sub-soil drainage, ventilation and so on.
Characteristics:
1.Free from weakness caused by rusting, weathering and chemical actions;
2.Healthy water, no secondary pollution;
3.Little resistance of liquid,high efficiency of transmission;
4.Excellent mechanic performance;
5. Light weight, convenient for installation and maintenance;
6.Reliable property;
7.High endurance of pressure, good property of sealing
