After Flapper Replaced....Multi-Flushes
Discussion in 'Toilet Forum discussions' started by MichaelBukay, Jan 16, 2013.
  1. MichaelBukay
    MichaelBukay Plumber
    Jan 14, 2013
    CA Plumbing Contractor, Working for the man in CO
    Conifer, Colorado
    Been running into a problem and have already found an acceptable solution. I still question though; when I replace some standard-looking toilet flapper with universal fit flapper from the supply house, why do the toilets flush more than once per lever pull? The flapper will stay upright until the whole tank is evacuated. As if the water is preventing the flapper from falling back down. I was having this problem mostly on Kohler toilets that weren't too old. I was thinking maybe I should buy the OEM flapper for each brand of toilet I run in to. I found an adjustable flapper that has sufficed for now. Any thoughts?
  2. jadnashua
    Few, if any, modern toilets since the mandated low-flow requirements, flush the entire tank during a normal cycle - they use the height of the water to provide more oomph for the flush. To accomplish this, they design their flapper to only stay up a certain amount of time. A universal replacement is unlikely to have that calibration, and will stay up longer, letting more water out. Enough water will cause it to do what you've seen. An adjustable flapper or an OEM, or one made specifically for your toilet as an aftermarket is the only way to drop the water use to the mandated amount. Using the wrong flapper, or incorrectly adjusting an adjustable one could use as much as twice the water mandated, and is a really bad thing in SoCal where water is especially dear.
  4. MichaelBukay
    Jan 14, 2013
    Conifer, Colorado
    thank you Jim. Your information and input is helpful.
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    If you know the toilet brand and model number, and the flush valve hasn't been replaced, then call Korky customer service at
    262-763-2434 and ask them what's the best replacement flapper for your toilet. www.korky.com
Similar Threads: Flapper ReplacedMulti-Flushes
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Toilet running randomly even after replacing flapper Feb 7, 2017
Toilet Forum discussions Toto Toilet Flapper closes too quickly Feb 6, 2017
Toilet Forum discussions Toto CST 743S flapper Jan 16, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
