After brief power failure, I have pulsating water and the well pump is cycling A LOT
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by JamesEarlJones, Jan 27, 2011.
  1. JamesEarlJones
    JamesEarlJones New Member
    Jan 27, 2011
    USA
    I accidentally cut power to the well pump while my wife was doing dishes yesterday. After I turned it back on, the water seems to be pulsating. It seems to have pretty high pressure, but there is a definite pulse to it. Also the well pump seems to be clicking on and off pretty constantly while we're using water. I've read a few things pointing to either a lowe pressure cut off switch, or maybe not enough air in the tank, but wasn't really sure if either of those could be what I'm looking for. Seems weird. Everything was perfectly fine before I killed the power. Thanks in advance.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I recommend turning the power to the well off and getting a pro out there to diagnose it ASAP. Letting the pump cycle as you describe will cause it to fail, and then you will have more problems.
  4. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    You probably ran all the air out of the tank when the power was shut-off by continuing to use water after the pump was off. The tank needs Air ASAP and if it's a bladder tank it needs a new tank.
  5. JamesEarlJones
    Jan 27, 2011
    USA
    thanks for the tips
    Ok, thanks for the advice. I have bought some bottled water to get us through until somebody can get out there to check things out since it looks out of my league. Will stop using water, and hopefully somebody can come out and take a look tomorrow. The pump tank appears quite old, so we'll see what he says. I'll update the thread with what happens just for the sake of anyone else who stumbles on this with a similar problem.
  6. ballvalve
    Dec 28, 2009
    northfork, california
    If its a plain tank, using all the water would have put air into the tank, and it would have been compressed when the pump went on. Not to mention the new air from the air maker sys.
    More likely a bladder tank.
Similar Threads: brief power
Pumps and Tanks Well Forum & Blog. Water is life. Brief pressure loss every 5 minutes? Nov 14, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Water turning off for brief periods Jul 5, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Well test results and brief history Jun 27, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Pump won't start except manually...briefly May 12, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Powering Well with generator... Jan 11, 2017
