Afci circuit with gfi extension cord?
Discussion in 'Electrical Forum discussion & Blog' started by chuck b, Feb 5, 2012.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Hi! I have rewired my enitire 800 sq. ft. cottage to code. Interior non-GFI protected circuits are wired on breaker AFCI's (non bathroom, kitchen, laundry, exterior circuits). I am thinking that when I use hi amp power tools I could benefit from connecting to an AFCI protected circuit, when using them with a GFI protected extension cord. Make sense? Thanks.
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    High-amp power tools are notorious for causing nuisance trips on GFCI devices. If you use 'em, be prepared
    to push the reset button every two minutes.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I'm not sure I see any need for having such protection, but there is nothing wrong doing it, and it will work.
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    I am very curious as to why you think this.
  6. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Guess the GFCI makes sense, but are you saying that the AFCI usage is in question? I did not mention that the wires for the AFCI are not new, and I am concerned that until I get the chance to take down walls to expose them and put in new romex, they could overheat, arc.
  7. jadnashua
    You said you did things to code, so, that means that you didn't put heavier gauge receptacles or other things on wire that was too small. There should be nothing to overheat. The only time you might overheat wiring is with bad connections, or using too small wire for the protection (i.e., circuit breaker).
  8. hj
    Circuit breakers are sized to protect the wire. If the wire overheats you used the wrong circuit breaker for it and it SHOULD be changed until the wire is upgraded.
  9. jadnashua
    You can use heavier wire than the minimum, but you can never use wire that is smaller than the minimum for the protection device, the circuit breaker (as long as you stay within the range of acceptable wire for the device- i.e., it has to be able to fit in the clamp or screw). As long as you do that, there should never be any overheating...the protection device would trip first.
  10. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    What power tools? How many Amps? I can't imagine any power tool that plugs in to a 120V recpt that would draw more Amps than a hot tub and they are all GFCI protected.
  11. jadnashua
    I'm guessing here, but I would guess a brush type motor where the brushes are getting old (and maybe not!) might give an AFCI a workout. If you've ever looking through the cooling vents, it's likely you could see all sorts of sparks occuring. It probably wouldn't unbalance a GFCI, but might an AFCI. Don't have any AFCI in my (older) place, so can't experiment without costs, and I'm not up for that at the moment.
  12. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I run my shop-vac, drills, saws, etc., on an AFCI circuit all the time.
    It has never tripped. Yet.
  13. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    I have had no trouble with motors in power tools tripping an AFCI. I have had problems with electronics making them trip, more specifically tools that have a soft start.
Similar Threads: Afci circuit
Electrical Forum discussion & Blog AFCI breaker (in Wisconsin) needed for dedicated light circuit? Jul 30, 2014
Electrical Forum discussion & Blog Afci & gfci on same circuit?? Aug 27, 2012
Electrical Forum discussion & Blog AFCI Circuit trips when I turn on lights Jun 14, 2008
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog Dedicated outlet for freezer in laundry room = AFCI? Jun 30, 2016
