Advice to stop teeny tiny leak?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thebordella, Sep 1, 2010.
  1. thebordella
    thebordella New Member
    Nov 9, 2009
    Ithaca, NY
    Hi,
    I recently posted about installing an icemaker line tapped off my well supply [http://www.terrylove.com/forums/showthread.php?38055-Help-identify-this-blue-pipe&p=269421].
    The job is now done but I have a very small niggling problem.
    Here is the configuration:
    1. Sharkbite Tee on 3/4 inch CPVC reduces to 1/2 inch
    2. Short stub (4 inch) 1/2 inch CPVC connects to push-on angle valve with 3/8 compression output
    3. 20 inch "faucet supply" (braided) 3/8 at both ends connects to angle valve and to adapter (below)
    4. Watts 3/8 to 1/4 adapter connects to braided "faucet supply"
    5. 1/4 inch icemaker line connects to Watts adapter and directly to fridge input
    I know this is a bit roundabout, but I could not find ANYWHERE to buy a push on angle valve with a 1/4 inch compression output, which is why I wound up with Steps 3 and 4.
    This setup works 99%. The two push-on fittings (Steps 1 and 2) are holding perfectly well with absolutely no leak.
    The connection between Steps 2-3 and 4-5 are also tight with no leaks.
    My only problem is the connection between Steps 3-4, where the braided "faucet supply" connects to the 3/8 inch end of the Watts adapter. I have tightened it and used some teflon tape but there remains a very teeny tiny leak. As in, a single water droplet at random intervals, maybe a handful per minute. I've redone the connection several times but the single droplet problem remains.
    Looking for both ideas on why this is happening and is there a clever solution to suppress the single occasional water droplet leak, that isn't a gusher or even a steady trickle?
    Thanks again!
  2. sirgloves
    sirgloves New Member
    Aug 19, 2010
    New Jersey
    I had a similar problem and fixed it by adding about 4 extra windings of teflon tape... I'm not an expert so I may wrong as far as professional installation goes but it worked for a simple DIY for me...
  4. jadnashua
    If you have what I think, both of those hoses normally have a gasket in the end, and the use of tape can cause a leak. The gasket against the ball end of the fitting should seal fine on their own. Also, overtightening them can be a problem.
  5. Dahlman
    Dahlman VP at Dahl Brothers Canada Limited
    Feb 25, 2009
    Valve Manufacturer
    Mississauga Ontario Canada
    Dahl has your valve
    Dahl #211-QG3-30 is a push-on valve with a 1/4 OD Compression outlet. It is a chrome plated angle valve. This will result in the following set-up:
    2. Short stub (4 inch) 1/2 inch CPVC connects to push-on Dahl angle valve 211-QG3-30
    3. 1/4 inch icemaker line connects to Dahl valve and directly to fridge input
    Send our office an email at customerservice@dahlvalve.com and tell them that you spoke with Thomas on the Internet, and that I want them to send you one on the house. It can ship from our plant tomorrow if you send them an email tonight.
    Please let us know what you think of it. Enjoy!
  6. thebordella
    Nov 9, 2009
    Ithaca, NY
    Thomas,
    Wow, thank you so much for your kind offer. I have contacted the customer service address you supplied with the information. I will be happy to post a followup when I install the new valve!
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If that Watts "faucet supply" is the kind that is supposed to prevent floods, you have made a big mistake. These are absolutely worthless. They tend to fail quite frequently.
  8. thebordella
    Nov 9, 2009
    Ithaca, NY
    I have read that about the flood prevention devices. But no, the only Watts piece in this assembly is a very simple 3/8 inch to 1/4 inch brass adapter, threaded male at both ends. The "faucet hose" is just your standard commonplace kind.
  9. Dahlman
    Feb 25, 2009
    Valve Manufacturer
    Our pleasure! I checked my email via our remote server and didn't see an email enquiry from you. Sometimes our mail server quarantines items. If you don't have a reply to your email by 10:00 am EST, then you may want to give them a call at 1-800-268-2363. Just press 1 when you hear the company greeting and you'll be routed to the Customer Service Dept. Tell them what we've discussed and they'll look after you. I'm on vacation...sort of :)...they have direct access to me all week even though I'm not there.
  10. ballvalve
    Dec 28, 2009
    northfork, california
    Mr. Dahl, can you post a link to your companys products? I like to buy American, but you Canadians are a good second choice. I saw your valves in a seperate post by Ian and they looked like a good piece of work.
    Distributors in California or on line purchase sources in US?
  11. Dahlman
    Feb 25, 2009
    Valve Manufacturer
    Hi ballvalve,
    Our website is here: www.dahlvalve.com. We have some work to do on our website so our Product Search function is somewhat outdated and the best information is on the Downloads page or uisng the "Build Your Own Mini-Ball Valve" function (if you need something unusual).
    Dahl qualifies for projects with Buy American requirements under the ARRA because we buy so much of our raw material in the U.S.A. That valve in the photo you saw in the other thread is made from American brass. Dahl is not simply an assembly plant - we design, engineer, machine, assemble, test, package & ship the finished product from our one location outside of Toronto.
    We sell to a number of supply houses in California. Your best bet is to find the local Dahl rep (on our website Sales Agencies link) and have them recommend a supplier in your area. You are also most welcome to contact our office directly.
    Thank you!!!
    Dahlman
Similar Threads: Advice stop
Plumbing Forum, Professional & DIY Advice Need advice: Would soldering stop this leak? Apr 26, 2008
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Polypropylene for Drain/Waste/Vent Installation Advice? Jan 4, 2017
