Advice on running waste pipe
Discussion in 'Remodel Forum & Blog' started by moa, Oct 17, 2005.
  1. moa
    moa New Member
    Oct 17, 2005
    Hi there
    I am planning for running a new waste line from the second story of my 1898 house to the crawlspace about 12 feet below. I will be running this through a stub wall which will give me a maximum diameter of about 3.5 inches. I have "as-built" architecture plans drawn up and will be applying for the requisite plumbing and building permits (I'm putting in a new bathroom).
    So a few questions, the pipe will have to do something close to a 90 degree turn at the bottom of the 12 foot drop due to a major structual beam below the stub wall, and then extend about 20 feet to the soil stack. With a 1/4 over 4 inches drop, this works out to about 5 inches drop over the 20 feet span.
    Q1. Is this angle too sharp? Would a long 90 degree span be sufficient?
    Q2. Is the "new" cast iron pipe of an external diameter that can fit in this stubwall? Can I (should I) mix cast-iron for the drop pipe and then use ABS for the span (due to weight?)
    Q3. Attached is a shot of my soil stack. Plan A is to cut the stack in the top span above the central Y, and put a new Y in in this place. Does this seem reasonable? Or due to the shortness of available pipe, should I chop the pipe lower and replace the whole shebang?
    Q4. At the top of the pictured soil stack on the top floor is the Y tha went to the former toilet. I have since removed this but the Y and toilet mounting is still in place. How should I cap/dispose of this?
    Thanks very much in advance
    -Nick
  2. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    since im up ill give you my opinion. others will be able to give facts.
    1/4 inch per foot is sufficient
    to turn horizontal you need a long sweep y with a cleanout
    should run pvc or abs the whole way from new bath to cast stack
    if my house i would replace the "shebang" if you have a decent spot to snap above the floor. either way you have to support the cast above the cut. i could be wrong but I think im close.
  4. casman
    casman New Member
    Sep 8, 2004
    New York
    I'd run the cast between the floors, it's quiet, I replaced with pvc and its very noisy, even with insulation and foam...
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    cast iron
    the cast is quieter between the floors..
    the 90 elbow will work just fine either on the
    top or on the bottom
    as far as fall 1/4 inch upstairs will work great
    in the basement it wont really matter too much at all
    because its going to be like niagra falls dropping
    down from the second flooor..
Similar Threads: Advice running
Remodel Forum & Blog Looking For Advice on Waste/Venting for Remodel. May 21, 2016
Remodel Forum & Blog Big problems arise after bathroom remodel: advice needed May 8, 2014
Remodel Forum & Blog I need advice on sorting slate tiles. Which issues should I avoid? Apr 25, 2014
Remodel Forum & Blog Bathroom remodel with wall hung toilet. Need advice on plumbing and venting. Mar 10, 2014
Remodel Forum & Blog Advice on gutting a bath in 1930's house Mar 6, 2014
