Advice on Power Vented Hot Water Heaters...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ttw4454, Jun 19, 2006.
  1. ttw4454
    ttw4454 New Member
    Jun 16, 2006
    I am in the initial stages of purchasing a power vented hot water heater. Does anyone have some advice on high quality brands, what sizes they come in, how long you could vent it, etc? Thanks,
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Rheem is a good brand. There are limits on distance, elbows, and pipe size, but the new ones use smaller pipe and can go greater distance than my 10 year old one. My old one uses 4" ABS/PVC pipe, but I believe the new ones can use as small a 2" and run like 30'. You can do a search and get the precise numbers.
  4. ttw4454
    ttw4454 New Member
    Jun 16, 2006
    Thanks Gary, I'll check it out.
  5. Wally Pfautz
    Wally Pfautz New Member
    May 19, 2005
    PV water heaters
    I am in the same boat and FWIW my research came up with Bradford White as a preferred unit. The 50 Gal is around $1000 and has a pretty good efficiency factor of .62 which qualified for a $50 rebate in Seattle. It use 3" PVC vents. Check the website for sizes and specs. www.bradfordwhite.com
Similar Threads: Advice Power
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Monday at 5:54 AM
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Polypropylene for Drain/Waste/Vent Installation Advice? Jan 4, 2017
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
