bgovoni
- Messages
- 3
- Reaction score
- 0
- Points
- 1
Hey guys, didn't know where to turn to but found this forum. I have an old style bathroom faucet that. The hot side has no flow going threw the output on the tub/shower. I have taken off the cold and hot side stems and inspected. The hot side I pulled out bits of rubber in the shaft. But still no flow. When I turn on the water without the stems, water flows directly out. So that tells me the middle stem that controls shower/tub flow has a problem or is clogged. But I cannot remove it... I am able to remove the nut that holds it in. Check out the pic, when I turn it it just turns. How can I remove it? I have tried wd-40 and lots of turning and wiggling...
I am at the point where I am about to just replace the whole assembly but if I can just remove the middle stem. It will save a lot of time and money.
http://imgur.com/74yCytd
