Advice on Concrete acid stain
Discussion in 'Remodel Forum & Blog' started by Mike50, Jul 1, 2006.
  1. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    I'm almost ready to do some DIY indoor acid stain.
    What garden sprayer that can tolerate acid would you recommend??
    What Dremel attachment should I use to remove some minor paint stains from concrete slab.??
    (I may use solvents as well-but they can smear)
  2. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    I used the cheapest sprayer form the hardware store to spray my floors. They are the only ones I found with all plastic parts.
    The drawback is that the ones I had dribbled. That leaves marks in the stained floor. Try one out with water before deciding.
  4. Mike50
    Jan 8, 2006
    Southern California
    Thanks mate. As it turns out plans changed-but I will keep that in mind.
    Mike
Similar Threads: Advice Concrete
Remodel Forum & Blog Concrete Demoliton Advice Nov 15, 2006
Remodel Forum & Blog Looking For Advice on Waste/Venting for Remodel. May 21, 2016
Remodel Forum & Blog Big problems arise after bathroom remodel: advice needed May 8, 2014
Remodel Forum & Blog I need advice on sorting slate tiles. Which issues should I avoid? Apr 25, 2014
Remodel Forum & Blog Bathroom remodel with wall hung toilet. Need advice on plumbing and venting. Mar 10, 2014
