advice on bulding up a shower base
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jfls45, Jun 11, 2009.
  1. jfls45
    jfls45 Homeowner
    Jun 6, 2009
    I live in PA
    I am installing a round shower base and need to elevate it a couple of inches or so to make room for the drain piping. What are some of the ways I can raise up the base without building a square base? I want the shape of the base to match the shape of the arc in this picture
    Jeff
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Round pavers and a dremel. :D
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Most excellent advice!
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Building shower base
    If you would just get a professional plumber to make a legal piping connection
    you would not have to mickey mouse the plumbing and make a platform
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Zackley:eek:
  7. Cookie
    Cookie .
    Oct 7, 2005
    This works too.
    I know someone who has taken a garden hose connected to their laundry sink, hung it up with a coat hanger, wrapped a hula hoop around it all with curtain, and it extends over the main drain in the basement, and that is their shower.
  8. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Dude,
    You are suffering and these posts are cries for help.
  9. jfls45
    jfls45 Homeowner
    Jun 6, 2009
    I live in PA
    Serious posts only
    I am not accepting anymore replies that are not serious in nature. Please only post serious answers to my questions.
    Jeff
  10. Dunbar Plumbing
    Apr 18, 2005
    [​IMG]
    Okay me behaves now!
  11. jadnashua
    What you are trying to do is always going to look like a kludge, and is likely to come back to bite you when you ever decide to sell the house, if not before. You should really consider doing it right now, than having to pay later.
    You could just make yourself a form and pour concrete. You'll have to figure out a way to make the height look good, getting a curved baseboard out of wood would be subject to moisture damage and not that easy. Doing it in tile would give you a tough edge to the base of the unit - you'd have to use small tile to conform to the curve. Not too many good options, unless you do it right.
  12. doc5md
    doc5md New Member
    Apr 11, 2009
    building a base.
    If you are dead-set in building up a base, here's what I would do.
    Put shower pan on floor. trace it out. remove shower pan. cut lumber (2x4 or 2x whatever height you need) to extend from the wall to short of the line by a measurement you will have to calculate from the materials below that you will pick out. I'd run lots of pieces and when you are done you will have roughly the outer contour. on the ends, I'd use something flexible like 3/8ths ply, followed by ditra, follows by a very small tile on a mes backing that will deal well with the curves.
  13. jadnashua
    Ditra might work, but the manufacturer specifies a minimum of 2x2" tiles. While not on a floor, if you knocked it just right, you'd possibly break it. RedGard would work to waterproof things.
    Still, better to do the plumbing right in the first place...
  14. Redwood
    Dec 15, 2007
    Service Plumber
    Yea Jeff,
    And us pro's are only accepting serious questions....
    [​IMG]
    Now quit huffing and get real!
    [​IMG]
  15. doc5md
    doc5md New Member
    Apr 11, 2009
    Ah yes, forgot about that. redgard is probably a better idea.
    Quinn
  16. Terry
    Aug 17, 2004
    Don't forget to buy more home insurance for that shower.
    Have you ever used a tub, or a shower that was built up?
    I have.
    It's one long step down when you get out.
  17. kingsotall
    Aug 17, 2008
    That first step is a doozy!
  18. jadnashua
    I was in a (cheap) old hotel in London one time where they did this...almost killed myself getting out, and I was only there a week.
    Some people will insist on a lousy workaround because they think it will save time, then have troubles forever after. Guess it's like beating a dead horse...can't get it to move at all...
  19. Dunbar Plumbing
    Apr 18, 2005
    And very dangerous on a wet surface. Doesn't matter what you weigh.
    Anytime I see a built up bathroom off the original floor,
    I think of FAIL.
  20. jeffc
    jeffc Journeyman plumber and Bacflow Assembly Tester
    Jun 10, 2009
    Kennewick, WA
    Jeff'
    You have had professional plumbers on two diffrent sites give you very good advice about how to deal with the shower drain problem. You must jack up the concrete and tie your shower into the existing drain line. Thiis is the only way to avoid any problems and possible dangerous repercussions from trying to do it cheap. You have also been very insulting to the people who are trying to help you. We are licensed, skilled tradesmen who are required to update and maintain our skill level in order to maintain our licenses. We work to make a living for ourselves and our families. Giving you free advice is not making us a living, but it is protecting you from yourself. My advice to you is that you take and heed all the good advice about the drain routing and stop offending these people who's help you may need in the future
  21. jfls45
    jfls45 Homeowner
    Jun 6, 2009
    I live in PA
    lighten up dude
    Come on now, I was getting replies that are making jokes of me and my plumbing skills, not once did I make a joke of any of your plumbing skills. I have actually learned quite a bit of information from you. but I have a problem. the cast iron piping goes to a gray water drain that I believe, correct me if I am wrong, does not allow for a shower hook up. So just hooking up to this thing is illegal. My other alternative is to redo all the plumbing which I can't afford and hook up to the septic system.
    Not sure what I should do in this case.
Similar Threads: advice bulding
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Polypropylene for Drain/Waste/Vent Installation Advice? Jan 4, 2017
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
