Advice on bar sink hookup: PEX --> Copper Stub Out --> Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bucky, Sep 14, 2012.
  1. bucky
    bucky New Member
    Feb 15, 2011
    Minnesota
    Some pictures.
    http://www.patrickdaley.com/11.jpg
    http://www.patrickdaley.com/12.jpg
    Before I remodeled my basement and built my bar I had some rough in plumbing work done to accommodate a sink. The supply lines are PEX and terminate at a copper stub out. I'm trying to determine the best way to go from the stub outs to the faucet. In a previous post I had thought about connecting compression shut off valves at the stub out and then running a faucet supply line. The issue I've run into is that my local code calls for no more than 30" on the fixture branch pipe. It's a 60" counter with the sink in the middle and the stub out is on the left side of the cabinet meaning that I have 30" of travel just going left to right plus the upward rise in height to get up to the sink.
    Ideas/Thoughts
    - Sweat some copper right to the stub out, route it to the middle of the cabinet, install shut off valves, use standard size faucet supply. (I guess this would be my preference since I have lots of spare 1/2" copper around, but is it acceptable to sweat copper to my stub out without installing a shut off valve?)
    - Run PEX from the stub out, install shut off valves, use standard size faucet supply.
    - Ignore the code! Shut off valves at the stub out with a 48" faucet supply line.
Similar Threads: Advice sink
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Shower/Washer/Sink Drain Advice Mar 16, 2016
Plumbing Forum, Professional & DIY Advice Plumbing Kitchen Sink. Need Advice on Waste Line. Sep 30, 2015
Plumbing Forum, Professional & DIY Advice Toilet Troubles... and maybe a sink too. Any advice appreciated. Sep 21, 2014
