Advice Needed - What would you guys do? (dehumidifier)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jonathan4465, Sep 24, 2012.
  1. jonathan4465
    jonathan4465 New Member
    Jan 24, 2012
    New York
    Hey! I bought a dehumidifier that allows a hose to attach to it. Emptying it has become tiresome, so I wanted to hook it right into the homes plumbing. I've attached a picture of the wall in the basement I want to set it up at. I was planning on elevating it, and then hooking up a trap to maybe the white pipe? I should mention that is a grinder pump under that cover, as I am slightly below grade. Any suggestions would be awesome! The rest of the basement is finished so this was the ideal corner to set something up.
    [​IMG]
  2. hj
    What is that "large white pipe" along the wall? Why is the pump's vent, I assume it is the vent, connected to it with a saddle tee? Why is the pump basin higher than the floor? Maybe lots of questions about an "inferior" installation, but the dehumdifier's drain can go into the pit anywhere, preferably through the opening for the cord, or a hole drilled in the cover, so it is not directly connected to the drain system.
  4. jonathan4465
    Jan 24, 2012
    New York
    Thank you for the reply. The large pipe comes from the 2nd floor bathroom\shower in the master. I can't comment on the vent with the saddle tee, but what I do know is in my development the town is responsible for the grinder pump and install. If it fails I just give them the serial number on the cover and they come out and replace it. They (the town) must have added the saddle tee at some point. The Yellowish pipe is original to the home.
    So I can make a hole in the cover and attach the hose from the dehumidifer to it? Don't I need a trap of some sort to prevent gasses from coming back through the pump? Sorry if my questions are silly to a seasoned pro...I'm trying to learn though!
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Hooking it up to it's own trap would work all summer long...
    ...but when the lower dew-points of winter arrive the dehumidifier would stay off, and the trap will dry up.
    It needs to share a trap with a sink or other active fixture to prevent the trap from drying, or be drained into a slab-sump or something. The condensate is cleaner than greywater, and can be legally/safely disposed of using just about any method.
  6. hj
    No sewer gases will come back through the pump, if the dehumdifier has one. If it is a gravity drain, the trap, a "sag" in the line would sork as one, would only prevent backflow when it was operating, usually in the summertime. Only an inexperienced person would have connected that vent to an "active" drain line, but since it was done with a saddle, that pretty much defined who did it.
  7. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    I've never seen nor heard of a room dehumidifier with a pump, but I s'pose they might exist. Most have a hose-fitting compatible with laundry hookups and garden hoses to be able to have it gravity-drain into a sink or sump.
Similar Threads: Advice Needed
Plumbing Forum, Professional & DIY Advice Concerning backflow [water contamination] issue, advice needed Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Advice needed on line size to new home Jul 23, 2016
Plumbing Forum, Professional & DIY Advice Water Treatment Advice Needed (See test results inside) Jun 17, 2016
Plumbing Forum, Professional & DIY Advice Advice needed - Bathroom Drain/Vent adding vertical santee Feb 8, 2016
Plumbing Forum, Professional & DIY Advice Well pump advice needed...... Feb 6, 2016
