Advice for venting new full bathroom
tippsand
Tennessee
Hi there,
I have a new bathroom studded out and can easily get below and above for plumbing lines. I'd like some advice on how to drain and vent the following:
toilet next to shower across from pedestal lav.
The main waste line for the house is located 4' down and to the right approx 15' (opposite the entrance to the bathroom). I am planning on running a new 2 1/2" PVC vent to the roof since I have a clear shot.
I think all the fixture vents can be vertical once they're above the flood height of the lav, right? The lav is what puzzles me. Will I have a long run of vent running 45 degrees through the wall?
See attached diagram.
Any help you can give me is great. Thanks!
tippsand
Tennessee
2 1/2" PVC pipe. You know, the white sched 40 stuff. Maybe you've never heard of it. I can't tell from your reply. I was under the impression that you needed something larger than 2" for a full bath vent with shower, toilet and lav. I'll run 2" if that's sufficient. The main stack for the house is 3 to the roof. It's cast iron.
No need to be rude either. Thanks for your advice.
Jimbo
San Diego, CA
I won't say for sure that there is no such thing as 2 1/2" pipe...there probably is. But it would be a custom order, minimum order quantity probably one skid, or about 600 linear feet. If you have a separate 3" vent stack already, the 2" would be ok for that bathroom group.....unless you are in a climate area which demands 3" for all vents.
Cacher_Chick
Test, Don't Guess!
If anyone makes 2-1/2" PVC, it would not be commonly found anywhere in the U.S.
The plumbing code varies depending on where you live.
In any case, your shower vent riser must come off the trap arm before the drain connects to the 3" line.
The vents must be vertical from the trap arm until they are least 6" higher than the flood rim of the sink. The lavatory vent could go straight up into the attic before being turned to combine all of the fixture vents before going through the roof. Horizontal sections of vents must be pitched to drain.
tippsand
Tennessee
I don't have a straight shot to the attic from the lav - the only path that's available is over near the toilet, so I was thinking that I'd need to run the stack in that wall. Could I connect the lav to the 2" stack by running through the wall or up and across the ceiling as long as I maintained a pitch to drain or is there a lateral distance restriction?
And for vents, is there a minimum fall / pitch to be considered "not horizontal" (ie 1 in 12)?
Thanks,
Gordan
SE PA
Depending on the governing plumbing code, there are restrictions on vents regarding maximal developed length for a given combination of fixtures and the largest drain size served. Beyond that, no restrictions on horizontal offsets above the flood level of the highest served fixture. Also... there is no minimum pitch on vents. They don't carry waste. They're not allowed to create a trap, however. You can actually pitch a vent downward to a vent stack as long as that vent stack can eventually drain somewhere.
You'll want all dry vents to come off the drain at 45 degrees or more.
Lavs and showers require 1 1/4" or bigger vents, the water closet will require 1 1/2" or bigger given the distances here. Bigger is not necessarily better, especially if it causes you to have to drill larger holes through structural members.
What are you doing about cleanouts? Depending on your code, every horizontal run may require them.
quote; 2 1/2" PVC pipe. You know, the white sched 40 stuff. Maybe you've never heard of it. I can't tell from your reply. I was under the impression that you needed something larger than 2" for a full bath vent with shower,
I KNOW what 2 1/2" pipe is, but you will NEVER find any waster OR vent fittings that isize. It is STRICELY used for water piping, (although I have had mechanical engineers, who should know better, specity it for drains and vents). The vents have to go vertical UNTIL they are 6" above the spill line of the fixturres, NOT after that point. Your shower is NOT vented.
Tom Sawyer
Maine
It's a job for a plumber. A licensed, skilled plumber. A plumber that understands the intricacies of DWV and will do the job correctly and to code with all of the necessary inspections. A licensed plumber that understands the need for sanitary plumbing and the danger to the public should things be installed wrong. The hack in the orange vest at the box store knows even less than he cares. I get rude when folks want to take on a project of this magnitude and they don't even know what standard DWV pipe sizes are available for christs sakes let alone how to properly vent a fixture or group of fixtures. So here's my advice. Pry open your wallet and pay a licensed professional. He will save you time, money and perhaps a divorce in the end.
