Advice for moving sanitary tee up
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wrkane, Apr 20, 2008.
  1. wrkane
    wrkane New Member
    Apr 20, 2008
    Huntington Beach CA
    Beginner here, so sorry if this is too simple a question. I am in middle of powder room remodel and need to move the sanitary tee for the sink drain stub-out up approximately five inches, to about 20" above the floor -- that is about the same height as the existing ankle stops. Below the tee I would use the standard ABS coupler, but what about above on the vent side? I am not certain what type of coupling to use there, or what the proper way to do it is. Also, should I move the ankle stops as well, as I have never seen these at the same height as the drain stub-out and it seems clearance can be an issue? Thanks for any help or tips you may have...
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'm just questioning why you are moving the drain. Is this a pedestal sink installation where the pedestal will not allow the trap to exit at that height? Or, a vanity installation where the vanity has interference with the drain at that height?
    If not why not use a longer sink tailpiece?
  4. hj
    tee
    The water lines should be fine where they are. You will probably need to use two ABS/ABS banded, NO-Hub type, couplings to insert the new tee and its pipe stubs.
  5. wrkane
    wrkane New Member
    Apr 20, 2008
    Huntington Beach CA
    The reason I need to move it up is the new sink sits on a rack, and there is a small shelf and storage basket on the bottom, so the trap cannot be in the way. There was a pedestal sink here before but no storage. I had a small wall cabinet for storage but it encroached in this small space and often I would graze my shoulder against it.
    Yesterday the big box employee said they the ABS couplings were all they had and was generally not helpful. Today I went back and found the Proflex coupling -- they were actually somewhat hidden at the end of the aisle and obstructed from view by their pricing placard. So I did the work today and ideally I would like to have moved it up a few inches farther, but the sanitary tee would not fit in between the bracket for the copper and the sink rack. So this will have to do, thanks for the assistance. Cannot wait to get the Toto Drake installed...
  6. Redwood
    Dec 15, 2007
    Service Plumber
    The proflex is fine in that application.
  7. jaivyjay
    jaivyjay New Member
    Apr 20, 2008
    i think the proflex is fine man.
    [​IMG]
    [​IMG]
  8. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Ankle stops? :) lol
  9. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    You should have cut the straps, put the T where you wanted it, taken off your plumber hat, put on your carpenter hat, and arranged other support for the pipes and stops.
Similar Threads: Advice moving
Plumbing Forum, Professional & DIY Advice Raising the roof.... Eh herm, ceiling. Advice moving plumbing and vents. Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Moving washing machine, need advice Sep 19, 2016
Plumbing Forum, Professional & DIY Advice Moving basement rough in, need advice Jan 29, 2014
Plumbing Forum, Professional & DIY Advice Advice on underground PVC repair couplers and moving earth Jul 2, 2007
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
