Advice for installing a shower base with an offset drain
Discussion in 'Shower & Bathtub Forum & Blog' started by cwilliams2000, Mar 28, 2013.
  1. cwilliams2000
    cwilliams2000 New Member
    Mar 17, 2013
    Boston
    I have a partially finished basement bathroom with a 1.5" drain line stubbed out underneath the surface level on the concrete floor. All the work from there is done, goes into an ejector pump that the current working sink and toilet use. I was thinking, installing the shower will be easy but then I realized that the drain is not centered at all. I have thought my only option would be to have a base built from scratch to line up with the drain, but is there another option for this, like a slightly raised base with enough room to reach the drain?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Most prefab shower bases have the drain slightly recessed below the concrete floor. This is why a shower rough-in should leave a 12x12 area with no concrete around the drain. This also allows the position of the drain to be moved a bit as needed when the base is installed.
    I would cut 12-18" of concrete out around the drain and dig the trap out so it can be moved.
    If you are in the USA, I would question the installation further, as a shower drain and any pipe under grade is required to be a minimum of 2" pipe.
  4. cwilliams2000
    Mar 17, 2013
    Boston
    There definitely isn't 12" around it, but perhaps 8-10", I will check the size again since it may be 2" maybe I am wrong there. Thank you the reply though I will get a pic also
  5. Terry
    Aug 17, 2004
    And make sure you have a p-trap, and a vent between the p-trap and any pumped basin.
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Shower drain must be 2 ".
Similar Threads: Advice installing
Shower & Bathtub Forum & Blog Need advice on installing tub faucets Nov 11, 2008
Shower & Bathtub Forum & Blog Need advice on installing a bathtub on uneven floor Oct 11, 2004
Shower & Bathtub Forum & Blog Bathroom remodel issues, need help and advice Thursday at 5:56 PM
Shower & Bathtub Forum & Blog Bad Tile Installer? Need advice Jul 17, 2016
Shower & Bathtub Forum & Blog Can't get trim off shower handles... advice? Apr 12, 2016
