Trabaja
We just had a Drake toilet (CST744SF.10) installed by a licensed plumber last Friday. He flushed it a couple of times before he left. It didn't leak when we didn't use it, but once we started using it, it does leak from the tank mounting bolt on one side. It does not appear to be leaking directly from the tank, but from water accumulated in the recess on the base below the tank and then through the bolt.
The plumber. who has an excellent reputation, returned, took the tank off, and carefully reseated everything. He was mystified. He did point out that part of the rubber tank to bowl gasket was dry and was suspicious about what might be causing that. After the re-install, the same thing happened. After we began to use it again, the leak reappeared. Our plumber said that even with the best company, a certain number of the toilets just have problems with the casting and fit and he felt this might be one of them. He said he has installed hundreds of toilets - it's not rocket science and they are set up to be pretty foolproof.
I am going to call the company tomorrow but I'm not quite sure what to say. How should I describe this problem and/or what should I ask for?
