adjusting new pressure switch?
lainey365
Got the new pressure switch installed and now water pressure is low. How do you adjust the new switch to change water pressure? Have installed the exact same part which is a Square D Pumptrol Pressure Switch w/ Pulsation plug interruptor. There is a spring with a nut on top. Is this used to adjust the pressure? Is tightening in creasing or decreasing the pressure?
One screw adjusts both on/off higher/lower. The other adjusts the separation between on/off.
