EDIT:
Bathroom remodel. ABS stack between kitchen adjoining kitchen san tee and toilet/bath san tee was cracked all the way down (1978 house). Replaced a large section of the stack, including kitchen san tee & trap rough in and I'm now working on roughing in the bathroom DWV piping. I'm basically copying what was in place before, but replacing all of the kitchen DWV pipe that is exposed.
Problem: I'm an idiot and wasn't paying attention to the vertical angle of a 13" (inch) section connecting the bath D/W lines to the stack. I was so concerned about the needed angle in the horizontal plane that I neglected to slope the small section of pipe. As it turns out, it's sloping ever so slightly (less than 1/8") over 13 inches. I have connected a 3x3x1.5" Wye to this section, to which will be connected another 40" of 3" ABS going to the toilet riser/flange. This 40" section I can easily slope 3/4" to 1". I'm hoping the combine drop from the toilet with the adequate slope in the 40" section of pipe will be enough to compensate for the minimal slope in the 13" section.
Question: Do I need to correct the slope in the 13 inch section or will the ~12 inch drop plus 40 inch run with proper slope compensate for my lack of adequate slope in the last 13 inch run to the stack?
Hopefully the newly attached pictures will help illustrate the situation. Note the section of pipe labeled "13 in section with minimal slope." That is the section in question.
