MorseCodeScott
I'm hoping the answer to this question is as simple as it appears, but I'm afraid it might not be.
I have a small room that I would like to add a washtub sink to. This room is on the back side of a bathroom, so I have an exposed wall with access to hot/cold water pipes which I can tie into and that appears to be pretty straight forward. I also see a drain or vent that I'd like to tie the sink drain into.
My concern is that I think this is a vent pipe though, so I'm not sure if I'd be messing something up by trying to tie into this. A few bits of information, this is in the basement so there is nothing below it, and the pipe goes right into the foundation. It travels up through the ceiling into a wall on the main floor, then I assume continues up to the second floor, but I can't trace it past there. I've turned on the sinks upstairs and went down to listen and see if there is any water draining in the pipe and i can't hear anything in it, so assume they all run into another pipe in a wall somewhere and that's what leads me to believe this is a vent.
So my question: Can I install a T just above the floor and run the sink drain into this? (I'm in New Brunswick, Canada in case that's relevant)
I've included a couple pictures to try to give a better visual. one is my crude attempt at a floorplan
