Adding Vent lines
Discussion in 'Remodel Forum & Blog' started by SavannahPL, May 15, 2008.
  1. SavannahPL
    SavannahPL New Member
    May 15, 2008
    I have a house built in 1920 and I have a few questions I need some advice on. The upstairs and downstairs bathrooms mirror each other and are stacked on top of each other. Both bathrooms are currenlty gutted.
    The upstairs tub, sink and toilet drain into a 4-inch cast iron stack which vents through the roof. The tub and sink drain lines ran under the upstairs bathroom floor to the cast iron pipe in notches they cut out of the floor joists.
    The downstairs tub, sink and toilet tie into the same cast iron stack as the upstairs but in the crawl space.
    The 4-inch cast iron stack is currently the only vent for the two bathrooms and I want to fix this.
    My plan was to tie the upstairs and downstairs sinks together on a run of 2-inch pvc and the same for both tubs, each with vent lines running into the attic. I have read For Pros by Pros Remodel plumbing and have a decent understanding of how to vent the system but my main question is below:
    1. As no previous drain lines have been run in the walls can I cut the holes necessary to run 2-inch pipe through the floor and top plate?
    The wall in question is between floor joists but I'm concerned, due to my own inexperience that this could cause structural issue. Am I wrong?
    2. Is 2-inch PVC sufficient size to drain two tubs?
    3. Can I use AAVs in the attic on both the tub and sink vent lines?
    I planned on replacing the portion of the 4-inch cast iron that's been wet for the last 80+ year but leave the upper portion going through the metal roof. So using AAVs would allow me to do this otherwise I need to take out the entire run so I can tie the tub and sink vents into it.
    THank you for any advice you can give
  2. jimbo
    jimbo Plumber
    2 inch is an adequate vent. AAV are not popular with a lot of plumbers, due to questions about long term reliability. They are not accepted by code in lots of places, but if they are accepted in your area, then that is one way to do it.
Similar Threads: Adding Vent
Remodel Forum & Blog Adding to Vent Pipe Jul 29, 2016
Remodel Forum & Blog Adding Bathroom in Attic-Wet Vent? Mar 29, 2006
Remodel Forum & Blog Bathroom Reno - Adding new tile and heating Jun 19, 2016
Remodel Forum & Blog Adding bathroom on second floor - DWV design Feb 8, 2015
Remodel Forum & Blog Adding stone veneer to basement project question.. Nov 30, 2014
