Adding utility sink to laundry room
brownmc
Hello, my name is Matt. First time caller... I have seen similar questions to mine posed but not exact. This is on a ranch home built in 2006 with open access to unfinished basement. I currently have top load washer, I am getting a stackable washer/ dryer. I would like to put a utility sink where the top load washer currently is. I was planning on adding a 2'' sanitary tee to the stand pipe (which is 2''), dumping the washer into the utility sink and taping off the existing water supply lines. The vent is somewhat visible in the 2nd picture, it is 1.5''. Is this legal? Is there a better way? My concern with the aforementioned is that it won't be very appealing to the eye having hoses running this way and that. Any information would be appreciated and if there's any pertinent info. I have omitted please let me know. I live in a small town about 70 miles west of Chicago. Thanks Matt
Pic #1: view from laundry room
Pic #2: view from behind my oven which shares the same wall as the laundry plumbing
Pic #3: view from basement looking up: laundry water supply and sewer tie in
Cutting a santee into the standpipe doesn't prevent what the vented santee is designed for. Siphonage.
In new construction, it would look like this. Or at least both fixtures vented to prevent a trap from siphoning.
Here both the washer standpipe and the laundry tray are vented. It only takes a few more fittings.
Cutting out the drywall and putting it back is pretty simple.
brownmc
Thank you for your reply. Oddly enough that photo you shared is one I found doing a google image search. I can't wrap my head around how to make that work in my configuration. I've made a crude edit to these photos, hope it helps and doesn't insulate anyone's intelligence.
brownmc
I guess I can't picture how I would vent the existing stand pipe as there is very little room to work with
That's why I'm suggesting you remove some of the wall cover. It's easy enough to plumb for two fixtures if the wall is open. You just have to be open to the options you have.
What you have now is a big restriction, the wall board.
There are at least three ways to do that right. They do include tying into the vent higher up, and tying in lower down. You may need to move the washer trap up a bit, or you may wye in from the floor below.
You said you will dump the washer into the sink. THEREFORE, all you have to do is remove the washer "P" trap and tee then install a new tee at the proper height for the sink.
brownmc
Thanks for the replies thus far. I was finally able to open up the wall. What I found looks pretty straight forward. However, there is a pipe coming out of the basement floor, into the wall (on the left), and capped. I do not understand the purpose of this pipe. I was thinking it was the vent for the drain in the basement (pictured) or the rough in for the basement plumbing. Pictures 2-6 follow the pipe in the basement to where it comes out of the wall and is capped.
brownmc
Here is a picture of the cap on the mystery pipe in the wall and my basement rough in which isn't far from the vertical pipe coming out of the concrete.
I know I had originally said I could just dump the washer into the laundry sink but really id like to put the laundry box behind the washer and dryer for a cleaner look. Thanks ahead of time.
index.php
This looks like a vent for the floor drain.
You have pipes capped off in the slab closer to the wall too. Is that a basement bath rough that hasn't been completed? It could be that the 2" pipe that is capped is the vent for that. In fact, I would not be surprised that the pipe near the floor drain is a vent, which was supposed to pick up the bathroom 2" vent, and up through the roof. The vent could revent at 42" above on the next floor to the existing vent.
The washer should have gone down a pipe that was purely for waste. A washer from above, or even on the same floor would siphon any trap downstream if not vented before entering the line.
I don't see the picture I need, which is maybe a line drawing of your layout.
brownmc
index.php
The capped pipes are for a basement bath: sink, toilet, shower, vent as the are labeled from right to left in that picture. The washing machine from above does dump into the waste side not into this vent coming out of the basement floor. They run very close to one another which might make the photos look deceiving. I will try to make a drawing. The pipe coming out of the basement floor goes up, over and up through the floor where it is capped in the wall. It is the pipe that is capped in the first picture I posted (vertical pipe far left in photo). It ties into nothing between coming out of the concrete and ending in the wall above.
brownmc
I couldn't rotate the thing, sorry
  • IMG.pdf
brownmc
Here is what I am picturing provided that the capped pipe does need to be tied into the existing vent.
brownmc
Excellent and thank you. Any idea on that capped pipe? Should it be tied in? Have you seen anything like this before? Perhaps a plumber taking a short cut?
brownmc
Does that additional vent need tied in within a certain distance? Stand pipe height on the washer is 32''? Anything I need to know about the height for the laundry sink drain?
I think it was a future something that was never completed. Now would be a good time.
Most likely, it was supposed to be a vent for the downstairs that was never tied in.
Pick up the landry sink first and measure. That's the best way. Some can be pretty low.
brownmc
Okay thank you, so if I use the double fixture fitting both the washing machine and sink can share the existing vent?
