Adding two lavatories to existing vent
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by prpsrv, Feb 12, 2009.
  1. prpsrv
    prpsrv New Member
    May 21, 2008
    Contractor/Real Estate Broker
    Los Gatos, CA
    I am remodeling a bathroom and want to use an existing vent pipe which currently serves only a bathtub. I want to add two (2) bathroom sinks in a 6 foot vanity. ech sink would have it's own trap goin straight back to the wall then make two (2) 90 debree turns to reach the drain/vent. The drain is a 2" galvi and reduces upward to a 1 1/2" vent (also galvi) which rises approx 8 feet throught the flat top roof.
    Thanks in advance.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Do you need step by step instructions or what is the inquiry¿
    Or is it a declaration¿ :)
  4. prpsrv
    prpsrv New Member
    May 21, 2008
    Los Gatos, CA
    I want to make sure the vent pipe will handle the fixtures
  5. kingsotall
    Aug 17, 2008
    Depends on the code your inspector uses. Here it wouldn't. Two inch roof penetration is required.
  6. hj
    sinks
    The vent pipe would be adequate as long as you connect to the 2" portion for the drains. Why does EACH sink need TWO 90's to connect to the main riser? That would normally be a "deal breaker" to a strict inspector.
Similar Threads: Adding lavatories
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Option for adding to my soil stack for second toilet. Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Adding basement kitchen DWV question Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Adding standpipe to existing sink Feb 1, 2017
