Adding to a Monoflow Heating System
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by angtort, Jun 8, 2005.
  1. angtort
    angtort New Member
    Jun 7, 2005
    Hi All, I own a split level house with monoflow heating with those old space-eating radiators. The main line exits the hot water heater & runs along the top of the ceiling, with two splits that I assume feed the rooms on the 2nd floor. It then crosses into the family room where it wraps around via baseboard (not part of the original heating system, added on afterwards but before I purchased the house). Then goes under the crawl space & feeds the remaining rooms on the 1st floor before finally coming around back to the boiler.
    I'd like to add heat to the room (it's a garage that's been partitioned off) adjacent to the family room. I've found the line that feeds the family room, and I assume is part of this heating circle. Question is, can I just cut a section of this line off, feed it to this "new room" (baseboard heating) and then connect the return back into the original flow so it continues onto the family room, etc... Or do I need some sort of tee, and if so where would they be placed?
    Thanks in advance for your help.
  2. hj
    pipe
    You do not give pipe sizes or some other critcal information, but from what you do indicate, I am surprised it works satsifactorily everywhere. Without seeing the actual system, we cannot tell you whether your idea is sound or not, but my feeling is that you do not want to do it that way.
Similar Threads: Adding Monoflow
Plumbing Forum, Professional & DIY Advice adding a loop in a monoflow system Aug 26, 2007
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Option for adding to my soil stack for second toilet. Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Adding basement kitchen DWV question Feb 3, 2017
