adding spray foam under installed tub
Discussion in 'Shower & Bathtub Forum & Blog' started by ta240, Jul 31, 2013.
  1. ta240
    ta240 New Member
    Jul 12, 2013
    Sacramento, CA
    I was working in our one bathroom, which is very much torn apart, and can see through the wall to our other bathroom shower/tub and there isn't anything under the assembly other than the couple little feet supporting it. Since we are using that shower/tub now I've really noticed it flexing underneath me as I move around.
    I know I've seen on here were some manufactures say not to support their tubs and this one has no brand name on it. But I was wonder if it wouldn't be a bad idea and also if it is even possible to get spray foam under that one while I have some access to it.
    Has anyone ever extended the nozzle on a can of spray foam? I only have access to it from the end so the extension would need to be around 4' or 5' to get down the length of it. Can a small rigid tube be added to the end of the spray nozzle?
    thanks,
    Trevor
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    It would take a heluva lot of cans to get there with can-foam.
    A 12 board foot FrothPak (or two or three) would have enough do something useful though. An inch of closed cell foam sprayed evenly over a fiberglass monocoque adds some structural rigidity, and 2" adds even more. To avoid stressing the tub you want to spray it in lifts of an inch or less. Too much expansion between the bottom of the tub and the subfloor could warp it or make it lumpy- the idea is to stiffen up the tub (and insulate it, which keeps the tub water warmer longer), not to support it on thin or uneven foam fulcrum point. The big box store home centers carry FrothPak kits- its' a 2- part 1.75lb density polyurethane, comes with a spraying gun and hoses,etc. It'll cover 12 square feet at 1" nominal thickness, and you can spray it from a couple feet back if you have to.
Similar Threads: adding spray
Shower & Bathtub Forum & Blog shower remodel adding body sprayer flow issues... May 9, 2007
Shower & Bathtub Forum & Blog Adding non slip surface to shower for older person Sep 1, 2014
Shower & Bathtub Forum & Blog Adding a step to an outdoor pool jacuzzi Jul 26, 2014
Shower & Bathtub Forum & Blog Problem adding shower to clawfoot Mar 5, 2013
Shower & Bathtub Forum & Blog Adding new vent fan...can I........?? May 20, 2012
