Adding Soffits and Insulation
Discussion in 'Remodel Forum & Blog' started by sctclimbs, Nov 8, 2008.
  1. sctclimbs
    sctclimbs Member
    Apr 25, 2006
    Colorado
    I live in Colorado and want to add attic insulation to bring my current R19 up to R49. I plan on using blown-in cellulose. I only have soffits at each corner of my home and would like to add more. The eaves have vinyl siding on them and the 4 current soffits are essentially the same material with perforations for air flow, obviously installed together with the rest of the siding. I cant find anything like that at HD. Can I just cut into the vinyl and add some cheap aluminum soffits. Good idea/bad idea?
    Also under the current R19 insulation there is no vapor barrier. It has been that way for the 40+ years this house has been around. How important is it to have vapor barrier below. It would be a heck of a mess to pull all that stuff up to add it but I would do it if it is truly important.
  2. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Check your state code on the amount of ventilation area required. Here we are able to reduce the required area from 1/150 to 1/300 if a polyethylene vapor barrier is installed instead of kraft paper.
    I recommend that you add the vapor barrier. Although it may be difficult now it may be next to impossible after you add more insulation. It will make the insulation more effective by keeping it dry.
  4. sctclimbs
    sctclimbs Member
    Apr 25, 2006
    Colorado
    Thanks.
    Any thoughts on cutting into the vinyl siding to add the soffits?
  5. Southern Man
    Jun 27, 2008
    North Carolina
    I'd have to see a picture or a sketch to make any specific recommendations. You should look through the siding manufacturer's literature and see what is recommended for termination and transition details.
Similar Threads: Adding Soffits
Remodel Forum & Blog Adding to Vent Pipe Jul 29, 2016
Remodel Forum & Blog Bathroom Reno - Adding new tile and heating Jun 19, 2016
Remodel Forum & Blog Adding bathroom on second floor - DWV design Feb 8, 2015
Remodel Forum & Blog Adding stone veneer to basement project question.. Nov 30, 2014
Remodel Forum & Blog Adding attic insulation over rock wool Feb 24, 2013
