Adding shower to bathtub
Discussion in 'Shower & Bathtub Forum & Blog' started by Clay, Oct 22, 2009.
  1. Clay
    Clay New Member
    Apr 25, 2009
    I want to add a shower to my existing bathtub. What do I need to put on the wall surrounding the tub to protect the sheetrock from water damage. Should I tile the walls or install a fiber glass enclosure? Any info will be appreciated!
  2. jadnashua
    If you want tile, tear the drywall off, install a vapor barrier, then cement board and then tile. Check out for help with tiling.
    A fiberglass tub surround typically can't be fitted to a tub that isn't designed for it so you'll have problems with the seal with the tub. You don't want drywall on the walls if you are going to use the area as a shower. Might be possible, but not likely.
    Also note, if the tub is a drop in, designed for use on a deck, there are other things you need to do to keep water from making a mess of things.
  4. hj
    A 3 or 5 piece surround will make a water tight enclosure, at least for a little while. They are notorious for coming loose from the walls or leaking at the seams if not sealed properly. A proper tile job becomes a major remodel project if the walls were not designed to be moisture proof, although a tub area is ALWAYS subject to moisture so it might already have the proper, or adequate, wall material.
Similar Threads: Adding shower
Shower & Bathtub Forum & Blog Adding non slip surface to shower for older person Sep 1, 2014
Shower & Bathtub Forum & Blog Problem adding shower to clawfoot Mar 5, 2013
Shower & Bathtub Forum & Blog Adding Shower to Existing Roman Tub set up... Dec 23, 2010
Shower & Bathtub Forum & Blog Adding a Shower to Roman Tub Jan 2, 2010
Shower & Bathtub Forum & Blog Adding a shower to a whirpool tub? Dec 4, 2009
