Adding new vent fan...can I........??
Discussion in 'Shower & Bathtub Forum & Blog' started by wrea398, May 20, 2012.
  1. wrea398
    wrea398 New Member
    Aug 22, 2010
    Hi guys. I have a slight issue with adding a new bathroom fan where there wasn't one before. The bathroom is on an outside wall and the fan will be about 5 feet from the outside wall. There is very little room to work within the attic space and it has a drop ceiling (12" mdf tiles). The tiles cant be rmoved without runing them as they were staples and glued in place. I was wondering if I could vent the duct at the soffit in the attic. Not just ending it at the soffet but actually cutting a square hole in the soffit and adding a wall style duct only having it facing the ground. Sounds stupid I'm sure but if you saw the area and type of ceilng I have to work around, you would understand. I have 14" above the tub window to exit a vent but access to the space over the drop ceiling is difficult. The attic is finished on the floor over the bath. Just trying to do something easy. Was hoping I could get away with NOT going thru the roof. Your thoughts?
  2. jimbo
    jimbo Plumber
    Venting into the eave... the area under the soffit.... can lead to dry rot and mold formation, due to the inability of the high moisture to go anywhere!
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    It doesn't sound like you have a drop ceiling anyways, but I suggest you drop the ceiling and replace it with a more modern on after you've run your rigid duct.
  5. jadnashua
    The warm, moist air wants to go up, so doing it in the sofit has problems with condensation as it gets trapped. An end wall, or one designed to go out through the wall, or through the roof has their advantages.
Similar Threads: Adding vent
Shower & Bathtub Forum & Blog Adding non slip surface to shower for older person Sep 1, 2014
Shower & Bathtub Forum & Blog Adding a step to an outdoor pool jacuzzi Jul 26, 2014
Shower & Bathtub Forum & Blog adding spray foam under installed tub Jul 31, 2013
Shower & Bathtub Forum & Blog Problem adding shower to clawfoot Mar 5, 2013
Shower & Bathtub Forum & Blog Adding Shower to Existing Roman Tub set up... Dec 23, 2010
