Adding hose bib
Discussion in 'Irrigation / Sprinkler Forum' started by laurelmd, Mar 2, 2014.
  1. laurelmd
    laurelmd New Member
    Mar 2, 2014
    MD
    Hello
    I have a new home and would like to add another outside hose bib. There are presently two which are running 1/2" cpvc off the main line and each with a shut-off valve. My thought is to add a third 1/2" cpvc with the identical shut off valve, and connect to the frost-free hose bib using an adaptor coupling. Is this a good idea? Should I instead transition to PEX and use a push-fit coupling to the hose bib?
  2. Terry
    Aug 17, 2004
    Either CPVC or PEX will be fine for adding the third hosebib.
    I prefer PEX. It' seems a bit more rugged.
Similar Threads: Adding hose
Irrigation / Sprinkler Forum Adding a hose bib to main irrigation line? Jan 6, 2009
Irrigation / Sprinkler Forum Adding new line (Anti-Syphon valve) Oct 14, 2013
Irrigation / Sprinkler Forum adding pressure Aug 21, 2009
Irrigation / Sprinkler Forum Adding outddoor water spickets Apr 13, 2009
Irrigation / Sprinkler Forum Difficulty adding new zones Jun 28, 2006
