adding cast iron radiator to existing system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bela05, Mar 5, 2014.
  1. bela05
    bela05 New Member
    Mar 5, 2014
    ohio
    i am wondering if it is a good idea to add a radiator to my basement. it's pretty cold down there(50) and i have acquired a beautiful radiator that matches all the radiators in my house. i have a hot water boiler and the system has a feed line and a return line. will this screw up the functioning of the system? would i be able to turn the radiator off at the valve when not in use and not mess up the circulation? and will the hot water circulate properly throughout the whole house when the radiator is opened up? i firmly believe in the "if it ain't broken" school of thought, but heat in the basement would be great. thanks for the help, bela
Similar Threads: adding cast
Plumbing Forum, Professional & DIY Advice Adding a clean-out to old cast iron and/or clay pipe Dec 2, 2012
Plumbing Forum, Professional & DIY Advice Adding a wye in basement cast iron stack Sep 24, 2009
Plumbing Forum, Professional & DIY Advice Adding cleanout to cast Mar 30, 2007
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Tuesday at 7:37 AM
