Adding bathroom on second floor, questions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JohnBinTN, Jan 20, 2012.
  1. JohnBinTN
    JohnBinTN New Member
    Jan 20, 2012
    Munford, TN
    Hi everyone. The subject line above should have been preceded by "maybe", I think. :) I'm just trying to get an idea of what will need to be done (probably by a "real" plumber for some/most of it).
    What we've laid out would situate the proposed bathroom almost directly above a 1st floor bathroom. There is attic space behind where the tub would go, as well as behind where the toilet will sit. Right behind the wall where the toilet will go is the main 3" (or 4"?) vent pipe through the roof, as well as another 1-1/2" vent pipe that the water heater and furnace drain to. On the exterior of the house, almost straight down from the location of the large vent is a (I think) clean-out at the foundation (two story house on a slab).
    My main question is what will be involved with plumbing the drain under these conditions? Will this require cutting into the slab to tie into the existing toilet drain line? If it makes any difference at all, we have a septic system, and the main drain to the tank is in the front of the house, while the existing 1st floor and proposed 2nd floor bathroom is along the rear wall.
    I'm almost scared to get someone in for an estimate, as we only have one child (so would rather not have to sell our first and only born to finance the project).
    Replies greatly appreciated (even if it's just something I can show to my wife that might dissuade her from this project!)
    Thanks,
    John in TN
  2. Terry
    Aug 17, 2004
    Here is a nice link to Bert Polk's plumbing tips
    The vent remains a vent all the way through the roof.
    You will need to run waste lines down past the first floor bathroom, and tie in downstream.
    Vents for the lower bathroom will need to go through the roof, or at least tie in at 42" above the second floor.
    [​IMG]
Similar Threads: Adding bathroom
Plumbing Forum, Professional & DIY Advice Adding a mini bar sink to bathroom drain line Sep 16, 2016
Plumbing Forum, Professional & DIY Advice New member, Adding utility sink on opposite wall of bathroom Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Advice needed - Bathroom Drain/Vent adding vertical santee Feb 8, 2016
Plumbing Forum, Professional & DIY Advice Drain layout for adding double sink to existing bathroom Oct 22, 2015
Plumbing Forum, Professional & DIY Advice Adding a branch line for addition of Master bathroom Aug 4, 2015
