Adding a utility sink in my Garage
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by manzo, Mar 2, 2005.
  1. manzo
    manzo New Member
    Mar 2, 2005
    Thanks in advance for your help with this!!!
    I am planning to add a utility sink into my garage. I have access to a 3" drain line that comes from the upstairs master suite tub, shower and two sinks (toilet has a dedicated drain line).
    My plan is to place a wye in the 3" drain line, com out of the wall at a 90 and then on to the p trap for the sink. In that Line from the 90 to the p trap I plan to install a T and send off and vent with a Studor vent.
    Will this work I expected? Any comments would be greatly appreciated.
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Slope all drain lines 1/4" per linear foot toward the main drain line.
    Check with your Building Inspection Department to see if air admittance valves (aka Studor vents) are allowed by local code.
    Good luck!
Similar Threads: Adding utility
Plumbing Forum, Professional & DIY Advice New member, Adding utility sink on opposite wall of bathroom Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Adding utility sink to washer drain Sep 23, 2015
Plumbing Forum, Professional & DIY Advice Help: Adding new Utility Sink and Washer Waste Wipe May 22, 2015
Plumbing Forum, Professional & DIY Advice DIY'er adding a sink in a utility room with washer/dryer Mar 3, 2015
Plumbing Forum, Professional & DIY Advice Adding garage utility sink - use existing 1st floor bathroom drain and vent? Nov 13, 2014
