Adding a Tee to an existing 3 inch PVC Line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rossirj, Apr 2, 2007.
  1. rossirj
    rossirj New Member
    Apr 2, 2007
    I am installing a new sink and would like to know if it is code (per 2003 IPC)
    to us a fernco instead of a repair coupling to add a tee to an existing 3 " line? I am wanting to add a 3" w/ 2" tee with a 2" to 1 1/2" reducer to then attach to the sink. At first a saddle tee looked promising until I looked at the other threads. My plan is to cement the bottom of the tee to the existing stub, cement a short 3 " piece to the top of the tee, then use the fernco to sew it up.
    Thank you in advance for any advice/information!
    Rob
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Use a banded coupling rather than the Fernco. A Fernco is not supposed to be used above ground. The banded coupler is similar to a Fernco, but it has a stainless steel band the full length of the sleeve instead of just the two clamps on a Fernco.
  4. rossirj
    rossirj New Member
    Apr 2, 2007
    Thanks Gary! Do they sell those a the "Big Box" outlets or do I need to hit my plumbers supply?
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    Can't say for sure, but Big Boxes should have them.
  6. rossirj
    rossirj New Member
    Apr 2, 2007
    Gary,
    Thanks again for the info.
    Rob
Similar Threads: Adding existing
Plumbing Forum, Professional & DIY Advice Adding standpipe to existing sink Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Adding tub to a bath with existing shower Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Drain layout for adding double sink to existing bathroom Oct 22, 2015
Plumbing Forum, Professional & DIY Advice Adding garage utility sink - use existing 1st floor bathroom drain and vent? Nov 13, 2014
Plumbing Forum, Professional & DIY Advice need advice on adding to existing DWV layout in basement Jun 13, 2014
