adding a light switch to GFI protected circuit
Discussion in 'Water Heater Forum, Tanks' started by Spook, Jan 26, 2012.
  1. Spook
    Spook New Member
    Jan 26, 2012
    retired
    Florida
    Gan a switch for overhead lighting be added to a GFI protected circuit without popping the GFI everytime you throw the switch?
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Sure. I have a GFI outlet out on my back patio, and it supplies power from its "load" connections -- "line" is for power in and "load" is for power out -- to the yard-light switch mounted in a box just above it.
  4. Spook
    Spook New Member
    Jan 26, 2012
    retired
    Florida
    Thanx
    I have a GFI outlet out on my back patio, and it supplies power from its "load" connections -- "line" is for power in and "load" is for power out -- to the yard-light switch mounted in a box just above it.[/QUOTE]
    THANX
Similar Threads: adding light
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Questions about over flow value and adding a expansion tank Feb 3, 2013
Water Heater Forum, Tanks GFI adding WH Jan 26, 2012
Water Heater Forum, Tanks Adding 2nd holding tank as pre-heat for incoming water Jun 2, 2009
Water Heater Forum, Tanks adding another hot water tank Jan 14, 2009
